Mooch,
What year is your Matrix?
If it's a 2008 or newer, it has individual tire pressure sensors in each wheel (direct TPMS). If this is the case, then chances are that one or both of the sensors were damaged when the new tires were installed.
If your 'trix is a 2007 or older, the car uses the ABS to monitor and compare individual wheel speeds (indirect TPMS). If there is a discrepancy (a tire with low pressure will spin faster than the others), then the light will illuminate.
Here's some good reading material on the subject - - >
TPMS Information
I hope this helps.
PlatinumVibe08
