Brutally rough ride - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2010, 09:27 AM   #1 (permalink)
View botski's Photo Gallery
Brutally rough ride
Hello,
My wife and I own a Matrix as well as a much loathed Ford Focus. When we test drove the Matrix it was on perfectly sculpted suburban street with hardly any bumps and it felt smooth as butter. When we took it home to the bumpy streets of our neighborhood it felt like the suspension was non-existent. It is so bad that I would rather drive my undependable Focus than get my innards scrambled in the Matrix. Almost everyone who rides in the car with us makes a comment of how rough it is.
Is there any dependable way to get this ride softer? A couple people I have talked to said "NO. It's all in the geometry". C'mon, it's all springs, right? Any tips are appreciated!
Bill
Edit: The car is 3 years old and has about 20K miles on it.
botski is offline   Reply With Quote
Old 01-15-2010, 11:05 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
The Matrix already has fairly compliant suspension as it is - you could run a softer spring, but with such a large sail area, you are trading ride compliance for overall vehicle handling. IMO, that is a poor trade-off. Sure you'd soften the ride, but get a good cross-wind gust, and you might find yourself immediately punched over another lane.
Assuming that you've already looked at the tire pressures - made sure they are not too high. Also made sure there was no physcial issue preventing the suspension to do its job (i.e., frozen coil or strut by ice jammed in there).
A more reliable and safer way to approach the ride are to adjust tire pressures (to a certain extent) or consider upgrading to a touring type of tire. Those have unique tire carcass that designed for a smoother, quieter ride while maintaining enough structural stiffness to provide good handling and stability. Tire pressures listed by the OEM may not be applicable for your driving conditions. Those numbers are generated to work in a wide range of conditions, but you may find that you'll have to run more or less pressure in the rear axle to compensate for the overall ride. Having that beam axle in the back will not help, but the right tire pressure and the right tire will make a huge difference in the car's handling and ride.
The OEM All-Season Goodyears on my Matrix were OK tires, but when I replaced them with dedicated summer tire for most of the year (have winter tires mounted separately on a spare set of wheels) - the ride was vastly transformed. Not Lexus smooth, but handled pavement irregularities much better than the OEM Goodyears. Now I "hear" the pavement cracks and whatnot instead of "feeling" them.
