GOOD FOR YOU!!
By keeping an eye on your fuel consumption you spotted a problem before others complicate the mix!!
My friend noticed same, but ignored it... then front cat went due to higher operating temperatures and the O2 sensor died also.
So that cost big bucks.
All caused by a 'loose' Air intake sensor.
Anyways, the symptoms described should prompt the dealer or yourself to check the air intake... is it clogged??
(not just filter but intake snorkel assembly, like a rodent nest, squirrel food cupboard, or it injested some other debris)
Do you have any loose / leaking vacuum lines?
loose sensor plugs?
and lasly is EGR valve stuck?
The Stealer
ought to have gone through all of that!
