5-speed Trans bearing failure - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2011, 11:25 PM   #16 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Originally Posted by tweezers View Post
I've got a 2007 Matrix 5 speed. I'm starting to hear a " ratchety " sound coming from the drivetrain. When I depress the clutch, the sound disappears. Possible trans bearing problem or maybe a clutch bearing ? Any ideas out there ?
If it is sound that disappears once you press the clutch, I can tell you this with 100% certainty, it is your clutch release bearing.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 09-20-2011, 12:55 AM   #17 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342366
iTrader Score: 7 reviews
Originally Posted by circuitsmith View Post
None of the complaints I've seen posted on any forum mention oil changes, but then neither does the owners manual.
Ignorance is not an excuse. I have always maintained my vehicles better than any suggested intervals say & I've not had issues. I use Redline MT-90 in my transmissions. My 07 Matrix was cahged at 30k miles & she still shifts great. I also put in MT-90 in my 09 Corolla at 25k miles. I just bought a 07 Corolla with 63k miles & I'll put in some MT-90 this week in that car.
+1
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 12-02-2011, 08:39 PM   #18 (permalink)
View McCuckerson's Photo Gallery
Input shaft bearing, when you depress the clutch you take the side load off the heli-cut gears. Ask me how i know: I did the autopsy on my old one last monday. This car is a POS. I also found plastic caged bearings and lost it.
McCuckerson is offline   Reply With Quote
Old 12-13-2011, 12:39 PM   #19 (permalink)
View TRDRadRedTaco's Photo Gallery
I have 119,250 miles on my 2008 XR. I changed the gear oil at around 100K and I was surprised how good it looked. It wasn't dark in color or anything. Sure hope I'm one of the lucky ones and it lasts....or maybe they did something different in 2008 than earlier???
TRDRadRedTaco is offline   Reply With Quote
Old 12-13-2011, 03:22 PM   #20 (permalink)
Gearhead
Gameroom cash: $196215
No changes between the 2004-2008 transaxles, as far as I know. Between the 2003-2004, there was a change to the syncros, to smooth the shifts.
Also likely that, given your mileage and model year, you have lots of stress free miles on the transaxle and beating on it like some others. Assuming that the majority out there are in the same way - no problems with the transaxle at all. Doesn't mean that for the ones that did experience issues, that it was all their fault - there is still a question of production line variance and potential QC issues with parts used.
Myself and my previous Matrix XRS 6-speed (C60), which was known to be hard on the clutch itself and pops 3rd gear out - I didn't experience those at all at almost 119K miles. I even towed with the Matrix, which should have put a lot more stress on the transaxle than the usual daily commuters.
Just stick with what you are doing, no need to worry about the car.
Old 12-13-2011, 07:36 PM   #21 (permalink)
Gameroom cash: $818401
View zythr's Photo Gallery
Why?
zythr is online now   Reply With Quote
Old 12-14-2011, 11:50 AM   #22 (permalink)
Gearhead
Back in the day, if I saw plastic used in that application - I would have flipped as well. But the stuff they use is some variant of a glass or other fibre reinforced polyamide material. Really tough stuff - flexible, low surface roughness, works well in lubricated steel application (slides easily), some cases can have higher dynamic and static loads - compared to steel cages, quiet, and doesn't heat up.
Toyota is not the only ones using them - lots of cars use them now. If it is "better" - depends on the application.
