Trying to change the fuel pump! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2010, 08:31 PM   #1 (permalink)
View MrUPS's Photo Gallery
For those of you who have been following my other thread, its the fuel pump (so the toyota stealer says) I was going to change it tonight and I cant get the stupid plastic retainer ring off! I got a tool from autozone that I thought would do the trick but its not. I am assuming that you twist it off counter clockwise but I've tried and it wont budge. any thoughts? thanks.
MrUPS is offline   Reply With Quote
Old 04-23-2010, 09:36 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Are you talking about the fuel pump support - the plastic "basket" that fuel pump sits inside of, has tabs around its base? That one, you have to pry off with a screwdriver. Once that is off, the fuel filter/fuel pump assembly slides out, disconnect the pump's electrical connector, disconnect the pump from the filter assembly.
Old 07-09-2010, 10:07 PM   #3 (permalink)
View tonyhawk's Photo Gallery
All it is a snap ring that fits in a groove. On the ends it should have little holes for the tool to squeeze them closer to each other so you can get it out of the groove. I have used needle nosed pliers before and got it out.
tonyhawk is offline   Reply With Quote
