What power steering fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2010, 02:14 PM   #1 (permalink)
View ventsyv's Photo Gallery
Question What power steering fluid?
The power steering fluid is a bit law on my wife's 03 Matrix. I bought Castrol ATF for imports
I think this should be OK to be used as a power steering fluid right?
ventsyv is offline   Reply With Quote
Old 05-07-2010, 10:04 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1002064
View humanoid's Photo Gallery
Some vehicles use ATF fluid for steering fluid, I would make sure you get the correct fluid for it.
humanoid is offline   Reply With Quote
Old 05-10-2010, 02:49 PM   #3 (permalink)
That's what I'm trying to do. Is there anywhere I can check?
Thanks!
Old 05-10-2010, 03:51 PM   #4 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Does the cap on the reservoir give any indication as to what type of fluid?
Old 05-10-2010, 04:06 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $617031
View Zembonez's Photo Gallery
Thanks!
Owner's manual will tell you what kind / type of fluids to use.
Zembonez is offline   Reply With Quote
Old 05-11-2010, 09:44 AM   #6 (permalink)
Gearhead
Gameroom cash: $196215
The type of fluid will be stamped right on the powersteering cap. That Castrol Import Multi-Vehicle would be OK for the transaxle, as I believe that is Toyota Type T-IV compliant. Powersteering can use ATF, but verify that is says Type T-IV or Dexron II/III ATF - the two are not interchangeable.
Old 07-23-2010, 09:05 PM   #7 (permalink)
View Billzebub's Photo Gallery
I noticed my PS fluid was low at cold, right at the min mark. I haven't added any in five years. I do not see a leak.
I went to Advance Auto and bought a Qt. of DexIII/Mercon ATF fluid and added about 3-1/2 to 4 tsp with a medicine dropper.
I will keep an eye on it for leaks, but I don't know if it evaporated, burnt off or what.
EDIT:
Sry, I should note that I drive a 2005 Tacoma DCSB SR5 4x4 SR5.
I found this post with Google search and didn't realize it wasn't the Tacoma forum until just now.
Billzebub is offline   Reply With Quote
Old 07-25-2010, 01:57 PM   #8 (permalink)
Gameroom cash: $266140
View shortlid's Photo Gallery
Over time it just evaporates off. I suck the old fluid out with a turkey baster every other oil change and replace it with new fluid. Seems to work well and keeps the steering tight as when new. Most Toyota's take Dextron III or better in the P/S system
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
