Did you reinstall the thermostat with the jiggle valve pointing up? There is a little dot or arrow that indicates how the thermostat should be installed, otherwise it may not open correctly.
Running an open thermostat from before, assuming this was done by the previous owner, actually would have cause more issues with overheating. Only thing I'm worried about is this was done to cover up a previous issue / problem with the car.
