Wheel spacer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2010, 07:36 PM   #1 (permalink)
View chrisanthony14's Photo Gallery
Wheel spacer
Hey guys.
I'm looking for a more aggressive look . I'm looking at the wheel spacers, what sizes are perfect for this car that don't need longer lug bolts?
Thanks,
Chris
chrisanthony14 is offline   Reply With Quote
Old 05-19-2010, 04:29 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
That would depend on the wheels and lugs that you intend to use. Rule of thumb is 1/4" before you have to replace the studs with longer ones. This works out to be between 6mm - 8mm spacers. I've seen people run up to 10mm spacers on the OEM studs.
If you can run those, you can do a quick test by tossing some washers on the lugs you have and seeing how many turns / threads you will actually catch. Note: Do not drive under any conditions if you put washers on for testing - this is for a cheap verification before you spend money on real spacers.
Old 05-21-2010, 03:19 AM   #3 (permalink)
yotatrix's Avatar
View yotatrix's Photo Gallery
This is very true and a lot ofoption for spacers depending on wheel offset. Also may want to check out matrixowners.com a few threads on this topic may help and some crazy wheel setups
2003 Toyota Matrix XRS
2010 Toyota Corolla S
yotatrix is offline   Reply With Quote
