Diagnose the issue before you go swapping parts. Like mikered30 stated, any CEL (Check Engine Lamp) indicated (you'll need a scanner to read the codes)?
Need a bit more information:
Car cranks and cranks when you turn the key to run but doesn't catch at all?
Verify that you get spark?
Verify that you get fuel?
Anything visually out of the norm - burnt wiring, cut, missing or damaged wiring/hoses, etc.?
Resetting the ECM to get it to restart makes it sound like the ECM is potentially a source of the problems - anything was changed/added/modified with the car before this happened (could be as simple as a new headunit or running extra electrical components)?
