Are you talking about the Twilight Sentinel feature (turns on lights, kicks on dash lights) or DRL (daytime running lamps)? They are two separate features.
The DRLs (headlamps automatically come on when you put the car in gear/remove parking brake), not much you can in that case other than to do a DRL disable.
If it is an issue with the Twilight Sentinel, could be an issue with the integration relay or the electronic eye is shorted out/malfunctioning.
