Winter rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2010, 10:47 PM   #1 (permalink)
View howe's Photo Gallery
Canada Winter rims
Hi ... my OE rims are 17 x7 x 45 offset , for the winter I can buy some cheap steel rims that are 17 x 6.5 x 39 offset . does anyone know if this will work ...my snow tires suit the OE rims....thanks
howe is offline   Reply With Quote
Old 11-28-2010, 11:44 AM   #2 (permalink)
Moderator
Gameroom cash: $571037
View silver04rollas's Photo Gallery
Yes, you can. However, with narrow width on the wheels, you will have go get your alignment re-adjusted everytime you swap your wheels. General rule is, if your width changes when you swap wheels or tires, the car needs to be re-aligned.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 01-19-2011, 09:54 AM   #3 (permalink)
View neuspeedescort's Photo Gallery
i have never heard this. how does changing your tires change you alignment? it doesn't.
as for rims. we have an 03 awd xr with stock 16's. we got studs for those and we have nice motegi 17's for the spring and summer.
NEUMAN
neuman speeds and neuman drives and drives an escort therefore i am / Featured in SCC Readers Rides March 2005 / 03 - Toyota Matrix XR AWD - 07-current / 93 - EGT/323 - 04-current / 91 - EGT - 07-current
neuspeedescort is offline   Reply With Quote
Old 01-19-2011, 11:00 AM   #4 (permalink)
Gearhead
Gameroom cash: $196215
Depends on the shop and their view on alignment.
Some shops will recommend an alignment any time the contact patch changes on the car from the previous setting. Some shops only recommend an alignment when gross suspension changes the angles.
Personally, I just go on where or not the car pulls and/or I start seeing abnormal tire wear. In fact, my 2002 Corolla has never seen an alignment since I bought the car late in 2001. Five sets of tires, three sets of wheels, new struts and performance springs installed. Some cars I've had couldn't go more than a year without something screwing with the alignment. A mix of being lucky and having a car that is forgiving of alignment mismatches.
Old 03-01-2011, 03:17 PM   #5 (permalink)
toyota200x's Avatar
View toyota200x's Photo Gallery
I would go with 195-65/15 tires. Narrower tire does better in the snow & is cheaper. 15" wheels fit. I have them on my Matrix XRS with snow tires on it.
toyota200x is offline   Reply With Quote
Old 03-10-2011, 10:23 PM   #6 (permalink)
View paladin_omega's Photo Gallery
That's not what's being talked about here. Of course you will most likely need an alignment if you make modification to your suspension. If you hit the curb hard enough you may need an alignment.
What is being said is that if you change your tires there is no need to get an alignment. That is 100% accurate. Your alignment doesn't even begin to play a role in changing your tires. If someone is trying to sell you an alignment while changing your tires it's a cash grab and you should not go to this shop. There is no "view" or "philosophy" at play here.
paladin_omega is offline   Reply With Quote
