night light for dash - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2011, 11:45 AM   #1 (permalink)
View zq_frank's Photo Gallery
I just bought a 2007 Matrix XR. There is one thing annoying me very much. I can not see the radio buttons and those air/heater switches at dark night. My previous old camry has a back light behind the daskboard, so I can see all the buttons after the engine start at night.
Is my light not working or there is no this function at all?
Thanks!
zq_frank is offline   Reply With Quote
Old 01-11-2011, 12:51 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Sounds like a burnt out bulb.
Remove the plastic fasia and change the bulb.
The Jedi Speeder at CarDomain
Old 01-11-2011, 03:11 PM   #3 (permalink)
Gearhead
Gameroom cash: $196215
Dimmer control turned all the way up?
Depending on the headunit, it may not be illuminated. The HVAC controls should be illuminated though, as mentioned above, likely a burned out bulb. I would suggest swapping out the other bulbs that you run across in there as well - that way you are only pulling the center trim off once instead of every time a bulb burned out. Same with the cluster gauges.
Old 01-18-2011, 09:00 AM   #4 (permalink)
Yes, the dimmer control turned all the up. I don't know how to take off the front panel. If there is a bad bulb inside, I will leave it there.
My 10 years old camry is still perfect, nothing goes wrong. I can see the quality is so different.
