It's pretty easy to replace the turn signal switch and doesn't require any special tools. Here is a walkthrough I found. Sorry I don't have the original poster's name to give proper credit.
First tilt the steering wheel down and remove the three Phillips screws from the lower half of the plastic steering column cover. One screw is on the bottom side of the cover just to the right of the steering wheel tilt adjust lever. The other two are on the front of the lower cover and may be hidden by the steering wheel, turn the steering wheel from side to side while looking at the cover through the steering wheel and you'll find them.
With the screws out, pull down on the plastic cover to separate and remove the lower half. Push up and to the right to remove the upper half.
The switch is held in place without any bolts or screws, just a plastic tab. Use the tip of a screwdriver blade to depress the black plastic retaining tab on the turn signal switch, remove the switch and disconnect the white wiring harness.
Install the new switch making sure to line up the tabs with the metal bracket and push till it seats. Reconnect the wiring harness. Test you work.
Replace the steering wheel covers, top first. This is the only part that takes a little patience. Be gentle, it will snap back into place. Once the top cover is in place, replace the lower cover and install the screws.
