P0304 and P0171 in '03 Matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2011, 03:10 PM   #1 (permalink)
View Buckeye25's Photo Gallery
So this is my first post here and it's not a good one... My 2003 Matrix XR AWD started to misfire about a week ago. I noticed it more during hard acceleration or low rpm's. It has gotten a lot worse within the last couple of days. It misfires/hesitates a lot more now. It is still only doing it during acceleration or low rpm's, but it runs perfectly fine after about 20 minutes of driving. I wasn't getting a CEL this whole time. I just replaced the spark plugs and that was not the problem. Today I was driving home from class and it finally threw out a CEL. It came on then would blink intermittently and then it eventually remained lit. I rushed over to Advance and these are the codes that popped up; P0304(Cylinder #4 Misfire) and P0171(System too lean). My first guess is the injector on cylinder #4, but I would like some suggestions on where I should start so I don't end up spending all of my drug money on this. Thanks!
Buckeye25 is offline   Reply With Quote
Old 01-31-2011, 09:08 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $533767
Anyway, does your car fit theses symptoms and how cold is it where you live?: http://ww2.justanswer.com/uploads/sk...rolla_0171.pdf
How many miles and when was the last time you changed the plugs? You could rotate the plugs and see if it comes back. How does your engine behave on cold start ups? Tach bouncing or steady?
mikered30 is offline   Reply With Quote
Old 02-01-2011, 08:00 AM   #3 (permalink)
It's below freezing here in Ohio and yes it has those symptoms stated in the .pdf. I changed the plugs two days ago with Bosch Platinum. It usually runs worse during cold start ups rather than warm. I don't notice the tach bouncing, but I start my car and let it warm up before I leave so I don't really pay attention to it. I will next time though. Oh, and it has 170k miles on it.
Old 03-26-2011, 08:15 AM   #4 (permalink)
EBR
View EBR's Photo Gallery
Have a look around the intake manifold where it meets the cylinder head. It is probably moist looking, like there is a leak.
If it looks moist, change the intake manifold gasket to the updated one. The new one is NOT black it is ORANGE.
After you change the gasket clear the codes and reset the ECM memory. Either by using the scan tool function or by pulling the EFI fuse for a minute.
Toyota Tech 11 years and counting...In the trade 18 years.
Current ride...02 Echo
Future ride...Idea scrapped...Selling all the parts I collected
EBR is offline   Reply With Quote
