Originally Posted by fishexpo101
Question: Does the distortion get any better/worse if you rev the gas pedal? Have you tried powering it straight from the battery?
If this all checks out OK - then you are left with a problem in the NAVI unit itself. Could be lucky and find it to be a blown fuse inside the unit (some are user replaceable, some are not). Could be the driver circuitry for the LED panel is faulty - broken solder, lifted pad, damaged wire, transistor(s) could be fired from a surge or other event.
Since you've already verified that the distortion is still present when you do not have the car running (just on ACC) - it is very likely that the problem is in the NAVI itself. Give the NAVI unit a good whiff, see if you can detect a very strong ozone/acrid burnt smell. Some ozone odor is normal, but it will should not be overpowering.
I will test for ground loops as you say. I've tried not hooking up the antenna as well but it made no difference. I'm starting to think its the head unit itself.
Not sure why i haven't tried just hooking up a battery to it to see if the distortion is still there earlier. Well, i hooked it up today in my garage away from the car, away from the antennas, away from everything and the distortion on the screen looks exactly like it was.
If you are familiar with the back of the unit, there are 2 plugs that go into, the bigger one has the power/ground/acc/speakers/antenna stuff and theres a smaller one. The big one i have figured out the wiring 100%. The small one not so much. The small one has some wires for CD Changer (which i dont have so they shouldn't matter) and it also has 2 other wires that the plug in the 2008 car does not have. From the Schematic i'm not exactly sure what those wires are for. 1 of them comes from the speedometer or cruise control (its hard to say exactly from the schematic). I did find this wire and connect it. It did not make any difference.
I found your question about rev interesting because the 2nd wire comes from there. I have not spotted it yet. But from the schematic it looks like it only makes a difference if the car is in Reverse. I have not tested it to see if there is any difference in the interference with the car in Reverse however.
With that said, considering that the unit does have the same interference issues with only 12v and ground connect to it would it be safe to assume that its a waste of time to look for the rev wire since its not likely to make a diff. As i've said early i THINK i'm narrowing down the problem to the unit.
1 thing that really bugs me is that it gets better with time. I've had a LCD computer monitor with a problem that got better with time. The culprit was a bad capacitor. But the problem was quite different other then the time thing. It was just a question of the monitor being dark for 30 min not getting enough power cause the cap was leaking (or something) but after a certain time to "warm up" the screen was perfect. Not the case here with this GPS unit. No issues with brightness, just the static.
I guess its time to take a look inside. As you say, maybe i can spot a bad component visual or by smell.
BTW, thanks for your posts. Its been very helpful. I've posted this question on other forums and noone has even replied.
