Originally Posted by taylor_f
If I could ask one more thing of you all. She is actually looking at the 2008-2009 models as well. Those being 2nd generation, could you all give me the scoop concerning those?
The 1st gens ran from 2003-2008, the 2nd gen started from 2009+
Completely different beasts, if you will. The 2nd gen feels smaller on the inside, not as cavernous as the 1st gen (some like that cocoon like feelings, others don't).
Cargo space was sacrificed to make the car sleeker in profile - conventional steering is now replaced by EPS (electric power steering).
Safety feature wise, the 2009+ Matrix had more standard content than the 1st gen - their so called "Star Safety System" which is made up of a VSC (Vehicle Stability Control), A-TRAC (Active Traction Control), 4-wheel ABS, EBD (Electronic Brake-force Distribution), BA (Brake Assist), DTPMS (Direct Tire Pressure Monitoring System) as well as your driver and passenger front and side airbags as well as front and rear curtain airbags.
The odd ones in the 1st gen Matrix where 2007 and 2008 model years (had DTPMS standard) and the 2005-2008 model years (had DBW like the 2nd gen).
Engine choices were revamped as well. 1st gen could be had with a 1.8L 1ZZ-FE or 1.8L 2ZZ-GE (Matrix XRS). 2nd gen offered the 1.8L 2ZR-FE or the 2.4L 2AZ-FE. The 1ZZ-FE and 2ZR-FE excelled at fuel economy - not unusual to hit 30MPGs with some smart driving. The 2ZZ-GE was more performance driven, required premium gasoline, and could be thirsty if you kept your foot in it, got as low as 20MPG with my foot anchored in the 2003 Matrix XRS - otherwise, I averaged about 25-27MPG with that engine with mostly highway driving. The 2AZ-FE is the Toyota "corporate" motor, used in other models like the Camry, Highlander, RAV4, Scion tC, etc. Though not as powerful as the smaller 2ZZ-GE, it runs on regular fuel and has quite a bit more torque off the line. Can be a thirsty engine - I've seen mileage as low as the high teens in my 2009 Matrix XRS - though typically I'll see between 21-25MPG.
Have to drive them back to back to really see the differences. If you can, I'd highly recommend having an extended test drive, overnight if possible. There are some "quirks" that you have to get used to on the 2nd gen Matrix, that might through off potential owners that were used to more conventional running gear. Other owners that have had similarly equipped car that stepped into the 2nd gen Matrix, didn't see any issues at all.
zythr makes a greatpoint about the Pontiac Vibe clone - all Toyota running gear, just with a GM name plate on it with some interior/exterior changes. Majority of the powertrain and electricals are identical to the Matrix.
