Simplified steps:
Remove radiator
- Disconnect battery (safety)
- Drain coolant
- Disconnect radiator hose inlet and outlet hoses
- Disconnect transmission cooler hoses
- Disconnect fan motor electrical connector
- Disconnect clamps for the wiring harness on the shroud
- Remove the fan bolts
- Remove the fan and electric motor
- Remove radiator assembly
For the waterpump
- Remove serpentine belt
- Disconnect wiring to alternator
- Remove alternator for extra clearance (2 bolts)
- Remove water pump (6 bolts)
