Need more information. Could you describe the noise you are hearing? Is it a scraping, ticking, grinding, thumping, etc? Metallic, high pitch, low pitch, seems to follow road speed, lower or higher intensity if you add more/less load?
Note that only a fraction of the all the Matrix 5-speeds seem to have problems. That said, I'd want to drain and refill the transaxle ASAP, just to see if there is any shaving in there that you need to keep an eye on. Brand and weight of gear oil seems to vary from car to car - some like heavier weights, some like lighter weights.
Personally, I like to stick with Redline MT-90 on all my manual transaxles that take a 75W90 GL-4 gear oil. Some have had great like with GM Syncromesh / Pennsoil Syncromesh gear oil in their cars. Especially if the shifter feels a bit notchy, get some grinding between gears.
