This will be a sticky situation - only thing that can possibly help you, is if you documented everything with some photos to show before/after taking the car to the dealership.
The procedure that the dealerships follow for replacing the ECM is outlined for them step by step. If you can get a copy of that procedure, that will tell you if they indeed had to move the carpet back. That will be the link you need to put the blame on the dealership. Don't bother talking with the service manager, unless they are on good terms with you, they will be just lip service.
File a complaint with Toyota Corporate and the Better Business Bureau - they should get back to you within a couple of days. If not, follow up with the dealership and Corporate. Keep your cool and document as much as you can.
But in the end, especially between the time of the original service to the problems you've had now - could be SOL. Just keep at them, get as much information as possible, any documentation that shows that they had to move carpet/shift AC drain tube out of the way - so that it puts the blame on them.
Good Luck.
