Since there were no XRS models available and I wanted lower compresion I settled for the XR and figured I would do a conversion later. Well, guess what, it would have been cheaper to pull the motor out of an XRS and swap to low compresion pistons when adding either a supercharger or a turbo setup. With a 10% over dealer cost hookup, without getting the disks, calipers or brake lines, I still spent over $800 for the rest of the parts!
The hubs were $250 or so for the pair, when they arrived the only thing I see different so far, have not done a test fit yet, is the plug in for the ABS sensor and I do not have ABS. My rear hubs may have worked! The backing plates were over $220 each but they do include the mount for the calipers.
The parking brake cables are most likely a must have item but now that I think about it, since I already knew they have the same brakes as a Celica GTS I may have been able to find all the parts from a yard for about 1/3rd.
Dang, hard to be patient though when I have so much to do to build this car. One thing though, I know I will have the right parts, my car is brand new, the parts will be too and no guessing on any damage, though likely easy to spot, on used gear. Brake failure is something I do not prefer to worry about!
Now I need to huntdown a serious sponsor, have one for a really big set of brakes but they still want $3,000!!!! If I go with an AEM big rotor kit, cost would be very reasonable and look decent but still have to buy rear calipers, $279 each, disks at $120 apiece or so and whatever the hoses are, these prices are also at 10% over dealer cost.
Bottom line, if you want rear disks and a boosted motor, get an XRS! You get the 6 speed, anti lock brakes, and a few other things for alot less than I am spending on changing my brakes! Lesson learned but then again, I have already picked up several $k worth of sponsorship just by being one of the very first to have a Matrix so I guess it is all worth it anyway and no need to pull the pistons.
All in all I still love the car, one of the funnest cars I ever owned, getting almost to where my 510 was but will take some history before it gets that big a place in my heart
Check my ad for a mint Momo Race steering wheel!
<font size=-1>[ This Message was edited by: RAAMaudio on 2002-04-18 21:28 ]</font>
