Part number for Toyota MAF O-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2011, 02:12 PM   #1 (permalink)
plu
View plu's Photo Gallery
Post Part number for Toyota MAF O-ring
This is just for reference. I kept getting a P0171, rev hunting when coasting to a stop and a rev drop down to 500 RPM when stopped for longer than 20 sec. so I cleaned the MAF sensor. Reinstalled and the low rev problem was still there. I took out the MAF to spray again when I noticed that the O-ring around the MAF sensor was stretched to the point where I can pull on it and it did not create a good seal. I went to Toyota for a new o-ring and they said that I would have to buy a new MAF sensor for $164. Toyota told me o-ring did not come seperately.
After some research online, I found Toyota part #90099-14141 from JAPAN that should work. I brought it at my local Toyota for $1.29 and it works like a charm.
You should replace your O-ring everytime you take out your MAF sensor to clean or whatever. The cold from the sensor spray kills the o-ring so I would replace it everytime. Hope this info helps someone.
plu is offline   Reply With Quote
The Following User Says Thank You to plu For This Useful Post:
fishexpo101 (11-03-2011)
Old 11-03-2011, 02:17 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Good stuff! Thanks for sharing that info - should come in handy.
