Matrix cold weather idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2011, 03:35 PM   #1 (permalink)
View poizone's Photo Gallery
I just inherited the family matrix, an 04 XR 5 speed with 170000. Living around cleveland as we do, the cold weather has always been a bit of a problem with idle after the engine has warmed up. Now that she is mine to take care of, I decided to see what I could do. I replaced the plugs at first, cause the old ones were pretty bad anyways, and checked the coils for cracks. Coils were fine, and she ran with a nice 800 idle for a few days. All of a sudden, she started to go down to 600, 500, and even dropped all the way below 400, and almost stalled out.
I adjusted the idle set screw, just a tiny bit, and now my idle is between 800 and 900. I know this is a little high, but other than the extra gas, is there a problem with leaving it? The ECU seems to be keeping the idle a lot more stable now, especially after coming down from a high rpm run, like 4k-6k to idle.
poizone is offline   Reply With Quote
Old 12-04-2011, 10:24 AM   #2 (permalink)
View circuitsmith's Photo Gallery
Try cleaning the throttle body, cleaning or replacing the PCV valve and pouring a bottle of Chevron Techron fuel system cleaner in the gas tank.
circuitsmith is offline   Reply With Quote
Old 12-04-2011, 10:56 AM   #3 (permalink)
Tech1984's Avatar
Gameroom cash: $256350
View Tech1984's Photo Gallery
I'm betting you have a deformed (shrunk) intake manifold gasket. Quite common.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 12-08-2011, 10:31 PM   #4 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $154550
View hardtopte72's Photo Gallery
I second the intake gasket. And also since it is an 04 clean out the IAC valve as well.
hardtopte72 is online now   Reply With Quote
