Originally Posted by prettyhatem
Hello all!
So I just purchased a 2006 Matrix base model, with 47k miles on it. The car is pretty clean, but one thing I noticed is that it has a rough idle. I haven't really noticed yet if the rough idle goes away when running the car for a while.
My real question is what should I be looking out for? It was owned but a one other person and carfax doesn't really show a lot of information about maintenance. So I was wondering if I should have some things checked out, and what should I look out for in the next couple thousand miles? Does this thing have a timing belt that needs to be replaced after a certain amount of miles? Any recalls I should look out for?
I just want to keep this thing in tip top shape and do any preventative maintenance I can do.
Thanks a ton!
Hi
No timing belt, timing chain, As for recalls, there was one for defective computer control modules in some models (Check VIN to see if your model was affected) which could cause stalling. Other than that, Matrix has not had many issues at all.
