05 front axle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2012, 12:01 PM   #1 (permalink)
View kedjc22's Photo Gallery
05 front axle
i just replaced my passenger side front axel the ( old one snapped in half just behind the nut.)So i replaced it did every thing the manual said to do i tapped it in with my brass punch until it bottom out then noticed the speed sensor cam was about two inces away from the hub i pulled the axel shaft out until the threads where out enough to put the nut.i removed the jack stands started the car put into drive moved about 6 inches tirned the steering wheel and it came apart the car was jumping off the ground like it had air bags on it what happend
kedjc22 is offline   Reply With Quote
Old 01-27-2012, 12:13 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Need a bit more info: Anyway you could post a picture of what happened?
- What came apart - the axle popped out, hub seared off?
- Where did it come off, the side closest to the transaxle, side closest to the hub?
- Put everything back in the right order, torqued down the bolts properly - replacing hardware as needed?
- Did you install the snap rings before it was installed, or were the snap rings already on the replacement axle?
- Did you tug on the driveshaft after installing it to make sure it was seated on the transaxle, before you threaded it through the axle hub?
- Did you unbolt the lower control arm to give yourself more room, of just tried to do it with the lower suspension arm still on the car?
Old 01-27-2012, 12:48 PM   #3 (permalink)
sorry about not enough info just getting a little frustrated the inner stub shaft that goes into the A/T is where the problem occured looks like u joints came out of the houseing as if the axel was to short one thing that i noticed is the orig one looks like the houseing is longer
Old 01-27-2012, 03:37 PM   #4 (permalink)
Gearhead
Popped out from the transaxle side - sounds like it didn't fully seat, even after you tapped it with the brass punch. If the snap ring wasn't positioned just right, then there is a chance that the axle will just fall out. Usually tugging on it after seating will check if it is seated correctly or not.
Also possible that you got the wrong part - happens more often than you think. Take it back, get a new axle, reinstall it. Before you set the car down - rotate the wheel by hand, see if everything is happy before you fire it up and start driving.
