Possible that the new one is faulty - seen it happen more than a couple of times. More likely, the P0303 CEL code was just a screen for something else that is going on.
Take the original coil pack, and swap it with the #1 coil - #1 is closest to the serpentine belt. Drive and see if the #3 coil on the #1 cylinder is acting up, ie. P0301 CEL. If you get that, then the coil is definitely the source of the CEL. If you still get a P0303 code with the #1 coil on the #3 cylinder - then you have something else giving you grief.
If you have multiple or random cylinder misfires now - could be related to a number of possible issues:
- faulty coil pack
- faulty spark plug
- faulty injector
- faulty fuel pump
- burned exhaust valve
- faulty ECM
- faulty O2 sensor
- clogged exhaust
- more
