foot pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2004, 03:02 PM   #1 (permalink)
Always on the Warpath--->
xrs22's Avatar
View xrs22's Photo Gallery
foot pedal
Does anyone know how to take off the stock gas pedal or does even supposed to come off?
xrs22 is offline   Reply With Quote
Old 12-16-2004, 03:47 PM   #2 (permalink)
XRS
View mistamatrix's Photo Gallery
The gas pedal doesn't "peel" off like the clutch or brake pedal.
You can remove it two ways I guess...
1) there's a pin behind the pedal that slides into the back of the pedal and the arm. The pin connects the gas pedal and the arm together. Remove the pin and you should be able to slide the pedal off the arm.
2) midway at the arm of the gas pedal assembly, there's 2 bolts. Unscrew that. Then at the top of the arm it's attached to the throttle cable. Take that off and you're done.
mistamatrix is offline   Reply With Quote
Old 12-16-2004, 07:09 PM   #3 (permalink)
xrs22's Avatar
thanx mista, i'll try over the weekend when i have actual time.
Old 12-17-2004, 09:49 PM   #4 (permalink)
XRS
Why do you wanna take it off anyway? Are you replacing it?
Old 12-18-2004, 04:46 PM   #5 (permalink)
xrs22's Avatar
Yeah, i couldn't figure out how to take it off so i just place the pedal on top of it. They're Redline race pedals. I also got some other ones, they're red but i think i'll paint them the same color as the car. But as long as i know how to take that damn bolt out.
