Alignment specs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2005, 10:41 AM   #1 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Alignment specs?
Well my mom's matrix is going to be getting 17" rims with 215/50/R17 tires along with a set of TRD lowering springs(she already has TRD front and rear swaybars and front strut brace). I need to know though the specs that I should align the car at after it is dropped with the springs?
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 03-16-2005, 12:41 PM   #2 (permalink)
Always on the Warpath--->
xrs22's Avatar
View xrs22's Photo Gallery
I guess it depends on how low it is now. You'll need camber plates if it's really low and an alignment. I have 1.5"F/1.8"R i don't need camber plates but maybe alignment but it drive staight as it is, just to be on the safe side though for tire wear.
xrs22 is offline   Reply With Quote
Old 03-16-2005, 01:00 PM   #3 (permalink)
SCCA Tech Services
Well right now it is the stock ride heigth since swaybars and strut bars don't lower the car. The only thing the car is getting as to lowering it is the TRD USA lowering springs and the 17's and 215/50 tires will lower it very very slightly. However lowering it any at all you will need new specs to align the car to because if you align it to the factory settings then you will still be off because the factory specs are for the car at factory ride heigth.
Brian Harmer
Old 03-16-2005, 09:29 PM   #4 (permalink)
XRS
View mistamatrix's Photo Gallery
It's in the service manual - http://www.toyotanation.com/forum/t52198.html
mistamatrix is offline   Reply With Quote
