Looking for Car Ramp Plans - Any Links you Know Of - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2005, 09:58 PM   #1 (permalink)
View Matreks's Photo Gallery
Looking to build some ramps similar to these:
http://www.discountramps.com/car_display_ramp.htm
I don't like jacks - too dangerous. Mosts consumer ramps are too steep for low front modern cars and don't provide access to the rear of car. Basically I want access to the entire underside of the auto from front to back and between the tires for oil changes, cleaning, and other maintenance. I will not be doing any tire service on these ramps.
LOL, Ideally a 4 post lift would be nice, but these are all several thousand dollars.
Haven't found any free plans on Google yet, but hopefully some will turn up (preferably in pdf format). I've had some previous experience in carpentry and my dad's a certified welder, but a set of plans would be helpfull as a starting off point.
Matreks is offline   Reply With Quote
Old 04-25-2005, 06:23 PM   #2 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
could always go 2 post hoist
rated_w is offline   Reply With Quote
Old 04-25-2005, 06:39 PM   #3 (permalink)
Pissed
View Camryamnesty's Photo Gallery
Or in ground single cylinder hydraulic lift...?
Oh anyways, check ebay you can prolly pick one up for about 200 bux
Camryamnesty is offline   Reply With Quote
Old 04-25-2005, 10:31 PM   #4 (permalink)
Yes, ideally a 4 post lift would be nice as I constructed my garage with 8 foot ceilings, but expensive unless you can fabricate the steel and hydraulics yourself. I've seen some nice portable ones which you call roll across the floor as opposed to a frame bolted to the floor. Not quite sure if I'd trust one of those 2 post ones though. I am not quite sure what the psi requirements for cement would be for a unit; I am guessing likely more than a 6 inch reinforced 3,500 psi concrete floor. Might require positioning on seperate cemented footings within the floor (as opposed to bolting it to a slab floor) to eliminate stress within the slab.
I did initially think of installing one or several pits within the garage floor, but opted out as I felt these would be rather restrictive and would cost $500-$600 each in materials (i.e., 8 inch block walls filled with cement and rerod and capped with a 6 inch slab.).
Here's some simple wood ramps I found:
http://www.mustangworld.com/ourpics/News/mwramps/
I am currently working on a simple car stand of my own design, which should initially provide 12 inches of work space under the entire vehicle. I'll try to provide an update and plans in the coming weeks. Its rather slow going now as its been raining, raining, and raining.
Old 04-26-2005, 08:32 AM   #5 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
my pop built one out of concrete....was a good pour job...only problem was it was steep at first...so we had to fill it in to be able to use my car on it....just gets me worried driving on it, like "am I driving straight on this?"
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is online now   Reply With Quote
Old 05-08-2005, 08:37 PM   #6 (permalink)
Hello...
Finally got some ramps built:
http://acer-access.com/~placebo@acer.../ramppic0.html
My primary purpose was too create a set of cheap and safe ramps which most anyone could create with a simple set of tools and simple materials:
Materials:
Standard construction lumber and wood construction grade screws. I built my ramps from recycled lumber from a 1940-50s farm building I tore down. It has a weathered look on the outside, but is solid inside (and actually is probably stronger than modern lumber as its from older growth forest). I plan to coat the ramp sections with some wood preservative I had left over from building a garage (probably not a good idea to put any preservative on the outdoor plywood cap since this may cause the plywood's glue to fail).
If I were to buy new lumber I'd probably go with treated green lumber, typically used for decks, as its rot resistant and I feel it holds fasteners much better than plain new untreated construction lumber which I find very dry. Green treat will cost more, but I feel its worth it.
The plywood I used consists of scraps left over from the construction of a garage. Although the plans call for 36" long sections of plywood I used smaller sections of scrap to cap the ramps as none of my scraps were that long. If I had to purchase new plywood I would use 1/2" (9/16") outdoor grade. I'd stay away from that wafer board made from wood chips as if it gets wet it effectively turns into "wet cardboard" over time). I also cut my sections of plywood slightly less than 36" (1/8" less) so that the plywood cap would not interfere with assembling the sections.
I had most of the screws on hand, but did buy a box of 3 inch screws for $8.00 + tax (my total cost as everything else was essentially free). I used construction grade green colored screws and some silver colored galvanized screws for securing the 2 X 6's together; and and shorter screws for the plywood.
Tools:
Saw (you can use a hand saw, but I would suggest at least a circular saw; however, a chop saw will be faster). The angled sections will probably be need to be cut with a circular saw.
Electric drill with a screw bit insert will save a lot of time! Pre-drilling holes should allow the screw head to countersink themselves into the wood as the downward torque of the screw will compress the wood around the head (using too light of screws may cause the screws heads to break off).
Square and a pencil for marking drill points. I liked to stagger the screws points slightly so the screws don't run into each other (such as on the inner sections) or cause cracking (i.e., too close to the edge of a timber).
Sander (belt sander, palm) may or may not be needed. If you find that some of the tongues are a little tight when sliding the section together simply sand them of both sides. A sander can also be used to sand off slight differences in the height of 2 X 6's before applying the plywood (lumber width typically varies from board to board).
Notes:
These finished ramps are around 6" high and 15 foot long, and provide enough access for me to slide completely under the entire length of the car using a wheeled mechanic's board (with several inches above my head). My 2005 Matrix XR, with factory side skirts below the doors, cleared the ramps with 4" above the car's "hang-up" point (i.e., when the front wheels are on the ramp, the bottom of the car in front of the rear wheels may hit the top of the ramp as you drive on if the ramp grade is incorrect - I crudely calculated this on graph paper at 3" using the planned ramp size, the wheel base, and tire size).
These plans can be easily modified to make higher ramps, such as using 2 X 8's or 2 X 10's instead (if you make the ramps higher the ramp section should be longer so as make the grade less steep so the vehicle does to scrape the ramp tops when driving on). The sections can also be made longer; however, I tried to keep each section to a maximum of 4 feet for storage purposes and a weight of 50-60 pounds. To facilitate the easy assembly of the sections I drew reference lines on the garage floor using a carpenter's chaulk line. I also cut some spacers of approximately 49" each, which are removed after assembly (overall width of ramp is approximately 72"). I also screwed a 2 X 6 stop at the front of the ramps so you cannot drive off the end and cut 4 similar loose stops for placing under the wheels so it cannot roll (though I do not think there is much chance of that since its level and the emergency brake is set).
Old 05-09-2005, 07:43 AM   #7 (permalink)
Always on the Warpath--->
xrs22's Avatar
View xrs22's Photo Gallery
I just use 2 pcs. of 1" slab of concrete along w/ 3 red bricks after it and then use a jack . My car is too low to get up any ramp w/ the bodykit that i have on there. I do everything on it myself anyway.
xrs22 is offline   Reply With Quote
