Slipknot the 05 models beep anoyingly increasingly quicker for 50 sec on passenger side and a 1 minute and 45 secs.. driver side. But ya I agree put you seatbelt on. it won't do it. As far as needing time well you have all the time in the world until you put it in drive and go over 15km/hour
Originally Posted by slipknot490
Geez, People...it is annoying but it only beeps 5 times. Either buckle up or plug your ears for a whole 5 seconds!!!
What you might want to do is find an old seatbelt extender. Basically, its just like an extra buckle. you plug this piece into the seatbelt clip by your waist. its always clipped in, so the it tricks the system. all you do is plug your regular seatbelt into it when you wanna wear your seatbelt. I wouldn't do it for passenger side, since the passenger sensing airbag would get tricked.
probably hard to find, but other than messing with the electronics, its the simple solution.
I got mine to turn off by adapting instructions on how to get the Prius to stop beeping in reverse. Here's how I did it:
Get in the car and turn the key to on (don't start the car,) then change the odometer to display "odo" and not trip A or B.
Turn the key off.
Turn the key back to on. Within six seconds of doing this, press and hold the odometer button. Do so for 10 seconds. Then, while still holding the button, buckle up, edit: then unbuckle. The "odo" display should then change to say "b-on." Push the odo button to get it to read "b-off." Then wait for the display to change back to the odometer. That's it, you're done.
The car will still beep right when you turn it on if you don't have a seatbelt, but it won't beep if you or your passenger unbuckles for a moment. Salvation!
If you're having trouble getting this to work, I did this on my 2005 Matrix XR 5-speed manual with the door closed and no one in the passanger seat.
did anybody else get this to work cause i have an 05 matix manual and could not get it to work. hey bazirker where did you find out about this or is there a step we are missing
92 Paseo to 05 Matrix big Pimpin now lol
I took instructions for a Prius and screwed around with it. I can't remember where I got the Prius instuctions, but they were a lot different.
Bummer that you can't get it to work, that's exactly how it works on mine...it's quite simple, just get in the car, turn the key to on (but don't start it,) push the odo button and hold it for awhile (I slowly counted to 10,) fasten your seatbelt, unfasten your seatbelt, and then push the button so b-on goes to b-off, wait for it to go away, and you're done. I just double checked my directions, and they work, at least on my car...
Maybe try it with the brake on or without the brake, I can't remember which way I did it. I had the car in gear (as it should be when parked) and with the emergency brake on.
