'05 Matrix Sunroof Leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2005, 04:35 PM   #1 (permalink)
View samfsu's Photo Gallery
Could anyone let me know if they are having issues with their sunroof / moonroof leaking? I was told that it is normal for a little water seepage and that the drains are internal. My headliner is not getting wet but there is a little seapage from the moonroof. Any thoughts would be appreciated.
samfsu is offline   Reply With Quote
Old 08-08-2005, 06:12 PM   #2 (permalink)
teh w00t sauce
Bazirker's Avatar
View Bazirker's Photo Gallery
With my '05 XR sunroof closed, I've seen no evidence of leaking.
What's seapage?
bllllllllllllllllllllaaaaaaaaaaaaaAAAAAAAAAAAAAAAA RRRRRRRRRGGGGGGGHHHHHHH
Bazirker is offline   Reply With Quote
Old 08-08-2005, 07:16 PM   #3 (permalink)
I meant to say seepage. Like in the corner of the moonroof i can see little water droplets. It Sux. I am not happy about this. Been to the dealer once already about this and I only have had the car for 3 weeks!! But love to car otherwise.
Old 08-08-2005, 08:59 PM   #4 (permalink)
View LoLo Blue's Photo Gallery
I got my 2005 matrix in the middle of winter and it rained like crazy this past winter and I saw no leakage. It is as tight as a drum and dry. It sounds like the seal around the window has a tear or is bunched up in the corners. If it is working right it should not leak. I called my dealer and he said its not normal, take it to the dealer and have them look at it.
LoLo Blue is offline   Reply With Quote
Old 08-08-2005, 09:25 PM   #5 (permalink)
Thanks Lolo Blue. I took it to the dealer once and they gave me some story about the drains being internal cause it is a moonroof. I had a moonroof on my acura integra and it never leaked. I mean the headliner is not wet but i am worried about mildew, etc....
Old 08-08-2005, 10:12 PM   #6 (permalink)
greywolf's Avatar
View greywolf's Photo Gallery
The drain is routed through the body of the car. If it gets clogged, water can back up and overflow. You should be able to pour water in the drain opening and see it pool on the ground. If it backs up, the drain needs to be cleared. The seal is not meant to stop all water entry. Any that gets in should go down the drain rather than back up into the headliner.
greywolf is offline   Reply With Quote
Old 08-09-2005, 11:03 AM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Damn that sux, since the car is new. On my gen3 camry I used to get water in my car from the sunroof and I had thought it was the seals but then I found out it was the drain tubes. One of them was disconnected and was also clogged. I would check and see if your tubes aren't clogged.
http://www.xclusive.bz
Old 08-09-2005, 04:02 PM   #8 (permalink)
Great info. Thanks! I mean it is not leaking like crazy just a little drip and it goes into what I think is the "drain pan" and then out through the drain tubes. I just thought that NO water whatsoever should come through the rubber seal but maybe you are right and sometimes a little water gets through...
I will say that I LOVE the matrix. My wife even drove it for the first time today for her commute and said she loved it. We bought a camry at the same time and she now wants to drive MY matrix hahahahaha.
Old 11-22-2011, 12:29 PM   #9 (permalink)
View kiltedtxn's Photo Gallery
I have a major roof leak from the sunroof. 2005 XR Just curious if anyone is still having this issue?
kiltedtxn is offline   Reply With Quote
