Do you mean getting into your car wetting the headliner, and the interior of your car?
Or just notice there is water on the channels when you open the roof? If latter, it's normal as water seaps in and channels out. If former, then go to the gas station and use the air compressor to pump out each corner of where the water channels. I had this problem on a really old volvo. Happens usually after the fall when dirt/leaves get stuck under my car clogging the drain holes.
2005 Phantom Base FWD - B Package
