Oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2005, 10:42 AM   #1 (permalink)
View imrealkewl's Photo Gallery
Oil leak
ok, I have this very weird issue. First I have an Matrix XRS with about 66k. What I have noticed on the garage floor is oil spots. However, it's not dripping all the time. What I have noticed is that when I run the A/C for a long time and park the car, the next day I see oil spots. Doesn't seem to happen when the A/C is off. Does this make sense, and where do you think it's coming from.
Please help i'm trying to sell it, but don't want to sell it with this problem...the car is in great condition other wise and has been real fun to drive and own.
imrealkewl is offline   Reply With Quote
Old 09-16-2005, 02:16 PM   #2 (permalink)
View Clamhead's Photo Gallery
Are you sure it's oil and not water? The AC system will condensate and drip water (as it's supposed to) after having been used. It does this while you are driving and will continue to do this after you shut the engine off until the system reaches ambient temp. All perfectly normal.
Take a close look at what's on the floor or pavement. Lay a piece of cardboard under the engine compartment if you have to, to catch the spots so you can look at them.
I'm betting it's water spots you're seeing.
Clamhead is offline   Reply With Quote
Old 09-16-2005, 02:39 PM   #3 (permalink)
Clamhead,
Yeah I thought it was water too, then I laid some plastic under the car, wanted to make sure it didn't soak into the cardboard, and yep it was oil. It's dripping closer to the drivers side, not the passenger side, where the A/C is located right? Bummer
Old 09-16-2005, 02:52 PM   #4 (permalink)
XRS
View mistamatrix's Photo Gallery
After reading your first post, I was gonna say it was just water condensating too.
mistamatrix is offline   Reply With Quote
Old 09-17-2005, 08:05 AM   #5 (permalink)
greywolf's Avatar
View greywolf's Photo Gallery
Condensate is a noun. The verb is condense.
greywolf is offline   Reply With Quote
Old 09-19-2005, 07:43 AM   #6 (permalink)
Sounds like a trip to your mechanic.
Old 09-19-2005, 10:37 AM   #7 (permalink)
Ok...I did an oil/filter change this weekend. Changed with Mobil 1 5w 30. Changed drain plug and washer. Took her to the car wash and degreased underneath the car. Ran the A/C all day, got home and guess what. No oil drips. Weird. Will keep an eye out though. Thanks...Still a great car to drive.
