Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - DIY: Door Sensor Repair
View Single Post
Old 06-17-2007, 12:24 AM   #15 (permalink)
Luspher
View Luspher's Photo Gallery
Originally Posted by PtBaller
wow I thought I was the only person having this problem which was caused by my body shop after I got my paint job!
If the problem started after the paint job, and they painted inside the door jams where the sensor sits chances are the bolt just isn't grounding. Check and make sure the threads it mounts too aren't covered with paint. if they are take the paint off and you should be good to go. The bolt is the ground for the switch.
Luspher is offline   Reply With Quote
