Hmm I am never totally sure. I am thinking wider tires than the 205's I have now.
Coil over suspension, possibly ksport as has been suggested, I want the adjustability of coil overs rather than lower it.
not going to lower it right down.
Bucket seat.
Full 2 inch exhaust
keep the 4af
increase compression, dual or quad carbs, larger valves with stronger valve springs, possibly bore it out a little. Stronger crank and connecting rods. Larger cams..
larger rad, maybe remove the A/C rather than fix it. Also thinking of a manual steering rack..
Not sure if I will put headers on it or not
Also not sure on the transmission yet.
Wouldn't mind a jdm rear bumper, and possibly a zenki front bumper as I HATE the kouki marker/fog lights. Trueno rear lights!!!
Ae86 panit scheme, all I have to do now is the red on the bumpers and the black on the doors between the wheels and I'll pretty much have that
Sound system? maybe a small sub in the trunk and an amp for the 4 speakers I already put in.
BIGGER BRAKES!
I have the rear disc conversion in my garage, basically I need the porportining block and rear calipers
