Originally Posted by 91boz
AE92 4AFE engine is very easy to do a timing belt replacement. Should not take more than a couple hours. Lock the tensioner to release pressure on the belt and slip off the old and slip on the new belt release and your all done.
I find there is no room at all to work on it! I have a bad back and if you do you will regret working on this thing with a lawnmower engine shoehorned into a shoe box. If it were out in the open or a normal car, yes it would be very easy(er). Use a air wrench to remove the bolt on the main pulley. Then, there is no need to lock the engine to remove the pulley bolt.
R&R the Timing Belt Tensioner (Bearing is sealed) with a new one too! as the tensioner usually causes the belt to go bad and break.
Do as everyone else said.
