Originally Posted by kevintomb
ANY lift at all will figure into extra gas consumption...its relative to how many percent higher it is off the road compared to what it was previously..sorry guys its a fact..the lower to the road the LESS air drag it will have. You may not notice much if you only lift it a small amount, but it will decrease the mileage..its simple physics.....
in an off road tacoma, the difference in being 12 inches off the ground or 14 make
ZERO difference in gas mileage and I'm living proof of that. you won't be able to find a difference by common folk mathematics. lifting my truck and keeping stock rims and tires made
ABSOLUTELY NO DIFFERENCE in my mileage. if you've lifted your truck, the thing has exactly the same aerodynamic footprint from the front of the truck as it is sailing through the wind....as the suspension lift is hidden behind all sorts of sheet metal. the only thing that is exposed more is another inch to an inch and a half of tire on each side of your truck. if you find a difference, you'll find that you'll have to calculate out to the thousanth degree or more......and that is rather complex physics, not simple at all....
Now, that being said, 1 inch off the ground vs 14 inches should make a significant difference....but I have no experience with ground hugging trucks or cars.
