Have you done the Sea foam/ Mystery oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 12-01-2008, 10:25 AM   #1 (permalink)
View rangerruck's Photo Gallery
did it to two diff vehicles at the same time. sucked in 6 oz through a glass
measure cup, through the brake line. the smoke was incredible. then did a second treatment and waited 1 hr. again, lots of smoke, and tons of water, and even a little goo, out the back of the tailpipe.
now the yota starts when you just look at the key, and the caprice, if you are standing in front , with the hood open, and cannot see the fan turning, you cannot tell the car is on.
p.s., make sure you car is allready warmed up, and running, when you add, and when you have added it all, turn the car off immediately, as fast as possible.
rangerruck is offline   Reply With Quote
Old 12-01-2008, 09:21 PM   #2 (permalink)
okay, lemme add this;
Okay, I am putting this in two places, and on other sites, as I don't know where it should officially go, but i want as many peeps and homies as possible to read this. I got totally bugged out , becuase so much speculation was going on here, with the one thread being 23 pages long, and 4 years old. I couldn't stand it anymore, so i called Sea Foam.
I was transferred to Jim Davis, Technical Director/ Research, of Sea Foam. and we had quite a cordial conversation, a real easy going guy, he is college educated, with a degree in automotive technology, has 35 years experience in the automotive repair industry , and is an A.S.E. certified mechanic. He has been with Seafoam, I think, the last 5 years, as his doctor told him, his body was just too out of whack, to handle mech work anymore.
So I will try to write as much as I remember, from my chicken scratch.
First off, I asked all the questions I wanted, such as , will it hurt, is it damaging to any parts at all, can it be used as maintenance, what do you do after you use the product, does anything need to be changed out, etc., etc.
First, he stressed multiple times, that this was a 100% petroleum product, nothing else. He said this many times during our conversation. he said there is nothing added, no fillers, no astringents, no mulsifiers, cleaners, detergents, nothing at all.
so how exactly does it work? Well , as you know, there is more than just carbon in your engine, there is salt , sulfur, all kinds of vox, and nox materials, you name it. How does it get stuck in there, and not filtered out? Simple, alot of the stuff we normally add, including gas, has a certain amount of sludge, varnish, lacquer, and gums added to it. This is the stuff, that sticks to walls, pistons, etc., especially when cooling. then all the other stuff we talk about, including carbon, gets stuck to this stuff, carbon, small micron stuff, other nox and vox particles.
Seafoam attacks and disolves the varnish, gum, sludge, and lacquer in there primarily, and then begins to break up , the other stuff.
Once this happens, all the junk is now freefloated back into suspension, and can be filtered out, or burnt out, of your various systems.
Seafoam does 3 other things primarily; controls and locks up moisture, adds lubricity without viscoscity, and cleans without adding any chemicals at all.
Does it harm other materials? In a word, no. He told me that right now, around their research area, they have multiple glass , sealed jars of Seafoam, with various things in each jar. plastic, rubber, seals, o-rings, pencil pieces, paper clips, bits and pieces of everything. Some of the items, in some of the jars, have not been opened or disturbed for 3 plus years now. he said, these bottles and items are studied through mag glass, and items looked at closely through microscopes, with no apparent natural destruction, loss, or dispersal,or disfiguration, becuase the item was sitting in Seafoam.
So you do not have to worry about your gaskets , seals, o-rings, etc., from exposure to seafoam.
he also said as a former tech, he did this same cleaning job many, many times, to multiple autos, and only one time did he have a problem.
It was with a car, driven by an old dude, who never drove it over 45 miles per hour, never put it on the highway, never got it hot, allways in traffic/city driving, and never driven over 20 miles, in either direction. he said it was just so full of carbon and junk, that the gum/lacquer did get on his 02 sensor, and a chunk of carbon did stick to that. he replaced said o2 sensor, and did another cleaning job, and the car drove like new. he said the old dude was so
impressed , becuase it drove the way it did , when he bought it new.
Again, 1 problem encountered, in all the times he did this cleaning job.
I asked will it harm injectors over time, or will it harm or dirty up the spark plugs, again the answer was no. As a matter of fact, he said, it will do nothing to the injectors but clean them real well, and it will proly make your spark plugs look like new, after a 2 or maybe 3 cleaning jobs.
I asked if it was too much, becuase gas contains cleaners and detergents in it as well, plus using this as a cleaner. he said no, because seafoam will clean out the detergents and cleaners as well, plus he said, only the really big gas peeps put cleaners in their gas, such as BP, shell, Chevron, Exxon, and even they do not put it in all grades of their gas. So if you are buying gas at Bud's truck and beer stop, it proly does not have cleaners/detergents in it.
OIL. I then asked about adding it to your oil and gas tanks; he said follow
the amounts on the directions, and you will be fine. Again, it adds lubricity and removes moisture, from you various systems, even the exaust system.
this is good , as i noticed, several drops of not only water, from using this on both my cars, but noticed a bit of goo coming from the 4runner pipe.
Specifically, in oil, it breaks up, and cleans up, all the junk in your oil system.
the longer you leave it in, the more it breaks up this crap, it should then be able to be filtered out of your system, and will turn your oil dark.
He said, how long you leave it in is up to you, the longer you leave it in, the more cleaning it does, then you can change your oil. then you can put more in, and clean again. You can keep doing this, until your oil system is clean, then do this for maintenance. the stuff that it breaks up and loosens up,
should not damage your system anyway, it should get filtered out, your pistons, and stuff will continue to smash this stuff up, and is stronger than the junk. Until it gets filtered out, or you keep changing your oil, until it starts to run clean for at least a couple thousand miles.
MAINTENANCE. I asked about maintenance, and changing out stuff; except for your filters, and the one bad example from above, you should not need to change anything else out. for using as regular maintenance, he said, not only is it fine, but he has been doing it for years. once his oil is clean to the way he likes it, and he thinks his intake system/injectors are clean the way he likes, then he just addes to his crank case, about every 6k or every other oil change, before he does the oil change a day or two, and adds for gas, to the recommended amt on the back of the bottle, so it keeps everything clean, lubed, and keeps out moisture.
i again asked specifically if it would harm injectors over time, he then went into a long story about injectors, and how you can balance them, and how they work, etc., etc., and then finally he said, no, it will not harm injectors, maybe cleaners or detergents in gas will , over a long time, but seafoam will clean out that stuff anyway, and again he said, only some of the big gas companies use cleaners, in all their diff levels of gas anyway as well.
Also when it comes to maint, it does such a good job of lubricity, he says it keeps the lacquer/gum , etc., from hanging on in the first place, which is what allows all the other stuff to hang onto, along the way. So he did recommend as maintenance, but not a lot, just after you have it cleaned the way you like, and you certainly need to do no more, than recommended maintenance that is described on the bottle. He said it really matter as to what you do, and how you are satisfied, some may find, that half or less the recommendation maintenance, works fine for them.
I am sure we talked about other stuff, and for longer, but this is as much as my scratchings have allowed me to remember right now.
As anectdotal evidence, besides doing my88 4runner, which it also got out the goo and water from the gas system/CAT/muffler/pipe( oh yeah, he did say it will also help clean out your CAT as well, he did 2 cleanings on one that smelt like Eggfarts, and after the second treatment, the stench was gone) I also did simultaneously a 92 chevy caprice, old school, with a 5 liter motor, with police interceptor package. i did two clean jobs with it, and if you saw my motor with the hood open, you cannot either hear, or see that it is running, it is that quiet now.
So today i actually drove it to work, and I also drive it for work, as I am a sevice tech, that has to drive to sites, to get certain work done.
One of the things that used to bother me a lot, was from a dead start, or red light, if i pressed on the gas a bit hard, i would for a second or two, get the 'clatter, rattle ' sound, as it first excelerated, like a diesel engine sound, and then it would go away. I would allways hear it, all the time, and every time. After the cleaning today, if I was not looking for it, I would not hear it, and when i was looking for the sound, i would just barely hear it, and that was only sometimes. i am looking for this sound to completely disappear soon.
Secondly , exceleration. This car is fast, and has allways been fast, but it was never what I considered quick, it was okay, but nothing special. Once it got up a little momentum, then it would giddyup.
Now, today, several times, I hit it up, at a stop light, or sign, or if i was allready on the highway, would hit the accelerator, as I was allready doing highway speeds. What throttle response!!!! WOW!!!! Not guessing, not thinking, but my A#$ss-ometer could easily tell, that as soon as my foot hit the pedal, my car would bow it's back up , like a wet cat, and take off, lickety
split, i mean the acceleration came quick , and easy folks, as soon as I hit
the pedal. And this car weighs a good 55oo lbs, not including all the wieight of all the crap i carry around in it.
Lemme show you;
Nice and old school, huh?
I have not driven the yota yet, but while sitting in the driveway, to start it up, i would just barely turn the key , for a split second, and it will start up, no prob, I think I will try a vulcan mind-meld for my next startup on the yota.
Anyway, I hope I have answered all question necessary about Seafoam, I know I have totally satisfied myself, with our conversation, and will have no
probs whatsoever, in using for serious cleaning first, and then as maintenance, without having to worry it is going to ruin some other part, gasket, ring, sensor, etc. on my vehicles. I say, use it to your hearts content. Thanks for the time, kids and homies.
p.s. , I know other dudes have other tricks of other stuff, that they add, spray, etc., but does it continue to lube parts, does it not add or subtract viscosity, does it not break down other stuff over time, does it continue to excorsize condensation, does it not erode injectors, sensors, or plugs over time?
Old 12-02-2008, 08:10 PM   #3 (permalink)
Saving lives
IronNam's Avatar
Gameroom cash: $580920
View IronNam's Photo Gallery
reading this, i think most VVT-i engines would love a cleanup for the VVT-i system!
94Hilux-XCab-22RE-W58-8"V6
IronNam is offline   Reply With Quote
Old 12-03-2008, 02:53 PM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
Nice!...It confirms what most of us here have said! Now you've made me feel a bit better about using Seafoam on my less than 30k miles car. I was going to wait until I at least got up to the 60k mark.
Good job.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 12-04-2008, 12:54 AM   #5 (permalink)
Saving lives
IronNam's Avatar
my engine is fine, but i need to change my rear diff oil!
the seafoam company makes great products tho
Old 12-10-2008, 10:03 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $268523
View Buurin's Photo Gallery
Heh, first I seafoamed my Corolla on a track and ran a lap with it still smokin' - REN has photo proof
A few months later I seafoamed my dad's Camry in the backyard of an abandoned industrial building, with groceries in the trunk It smoked for 20+ minutes and just refuses to stop!
From what I remember, Seafoam is a mixture of three major components: some proprietary stuff, something that escapes me (lol), and isopropanol. One usually divide a can into three, a third into the engine oil, a third into the tank, and the most dramatic third to be sucked down the brake booster hose, producing all the smoke we've come to amuse ourselves with and love.
Little Pig. You are ready.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-14-2008, 12:56 PM   #7 (permalink)
Altima_shift
porschebk85's Avatar
View porschebk85's Photo Gallery
I'm glad the seafoam was finally proven safe to all. I've used it twice in my Altima with around 120K and had no issue's at all. And it helped increase acceleration immensely, the car never use to be so rev. happy.
Never used it in the oil though, I wouldn't want to unless I was near time for an oil change.
porschebk85 is offline   Reply With Quote
Old 12-14-2008, 02:45 PM   #8 (permalink)
again, just what repeating what the research/spokes-tech told me, it is 100% petroleum product. i don't know all the ingredients that can be made from oil, so I do not know if Iso is one of them, but I don't think so.
i am also still trying to get a hold of the dude again, and see if I can get some indi-third party research on it, just for more giggle factor.
Anyway, from talking to the dude over the phone, and you know when you are talking to a guy with multiple years of service work, you know when someone is either b.s.'ing you, or doesn't know what they are talking about, I don't get either of those vibes from him at all.
So I will let you know what other info i gleen.
I say, use and be happy about doing it.
Old 12-14-2008, 07:31 PM   #9 (permalink)
View suprabran's Photo Gallery
Is sea foam like the B12 Chemical in auto zone, Napa, and other stores? If so which is the best or are they basically the same? Another question on marvel Mystery, do you put it in the brake/vacuum hose too? I have never thought it would work there, does it work the same as the sea foam?
suprabran is offline   Reply With Quote
Old 12-14-2008, 09:26 PM   #10 (permalink)
Seafoam is def sold in autozone, it comes in a steel can, with a white label, and I think red print. I can't vouch for the others you mentioned, but mystery oil is also sold to be used the same way as Seafoam, though Mystery oil contains other chems I believe, and it is red. So if you suck it in your brake vacuum line, you will be putting something I guess like red dye in your intake.
But it if you read the directions on Marvel Oil, it is to be used very similar to Seafoam, in same amounts.
But like I said, I don't think it is 100% petroleum like Seafoam, that said, I wouldn't hesitate to try it the same way as well, plus it is about half the price
of Seafoam. I'm gonna stick with Seafoam for the intake treatments though.
Old 12-15-2008, 05:28 AM   #11 (permalink)
View Albuynp Ryeno's Photo Gallery
Seafoam is snake oil, plain n simple. I used it on my camry v6 and ended up needing to change the rear bank spark plugs. I removed the intake plenum and surprise surprise, the plenum is coated in a dark black layer of carbon.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 12-15-2008, 10:27 AM   #12 (permalink)
sounds like you may have not used it right, what exactly did you do?
Old 12-15-2008, 02:51 PM   #13 (permalink)
Gas tank at yellow light. Half into tank. Then the other half of the can into brake booster. Car chugs, almost stalls, then turn it off once all the fluid is sucked up. Wait 15 min. A good amount of white smoke.
But like a week later when i went to remove the intake plenum, it was coated in a black layer of stuff.
IMO your better off removing your intake manifold and submurging it into cheep engine degresser for 5 hrs. It'll do way more then anything seafoam does.
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Old 12-15-2008, 07:27 PM   #14 (permalink)
first off did you do the treatment with the engine running , at normal operating temps? in other words, after allready running, or you start up, and let idle for about 1o to 15 minutes. Also, you turn off, and let stand for at least 5 minutes, I like 15. and you turn the engine off, as absolutely as fast as possible, as soon as it sucks up the last bit of stuff. then, you need to do a second treatment. You also only need to do 6 ounces at a time. so you divide your can into 3rds. Yours is about 5% of the results; so dirty, that the stuff partially liquifies the sludge and carbon, but because it is not hot enough, and you have so much junk in there, reattaches to plugs. your second application should be right away, not whether you think you need it or not.
Old 12-15-2008, 10:52 PM   #15 (permalink)
Why would you turn it off? Being off would it make more sludge? I thought you run the car till normal opperating temps, then add it to the intake brake booster and then run it again and keep it running so all the carbon desolves. I have never done this before, but wanting to try it so I want to make sure it is the right way. Thanks guys
