My 08 Camry MPG Record - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 04-24-2009, 02:48 PM   #1 (permalink)
GSW
View GSW's Photo Gallery
USA My 08 Camry MPG Record
Back in the winter I was getting 33 mpg with 34 on occasion. Now with warmer weather and 35-36 lbs of tire pressure I'm up into the 34-35 mpg range. latest mpg was 35.98 mpg!!! That's hybrid territory for sure. I'm happy
2008 toyota Camry LE, 2.4L *gone*
2010 Prius II
GSW is offline   Reply With Quote
Old 05-04-2009, 12:21 PM   #2 (permalink)
GSW
Scratch that record! The Camry just got 37.1 mph!!! Top that folks...
2010 Prius II
Old 05-04-2009, 01:13 PM   #3 (permalink)
View Daox's Photo Gallery
Haha, congrats on the good mileage.
Daox is offline   Reply With Quote
Old 05-04-2009, 02:56 PM   #4 (permalink)
GSW
Thanks!
2010 Prius II
Old 05-04-2009, 07:47 PM   #5 (permalink)
Gameroom cash: $279585
View worthywads's Photo Gallery
Good work.
If your tires are rated for 44 git'em up there. I run 44 minimum and inflate to 50.
I'm at 38K with the cheap stock tires and I'm expecting 45-50 before retiring them, I see no center wear that most that have never tried it warn about.
If you are not at cleanmpg.com already it's a great site to learn more about increasing your mpg.
2005 Impulse Red 4x2 Access cab 2.7L 5-speed SR5.
worthywads is offline   Reply With Quote
Old 05-12-2009, 01:50 PM   #6 (permalink)
GSW
Thanks all! Just filled up and she's dropped a little...36.4 mpg. I usually round off to .25 or so after the first gas pump click, but I've been told to make sure its getting to the top, so I stuffed it, AND still got over 36 mpg. I know if I took readings the same way as I used to it would be getting 37+ mpg.
2010 Prius II
Old 05-29-2011, 04:05 PM   #7 (permalink)
View kevintomb's Photo Gallery
How are you getting such high numbers...??...Some additional info. What kind of speeds, what type of roads, what are you doing unusual.
kevintomb is offline   Reply With Quote
The Following User Says Thank You to kevintomb For This Useful Post:
LostSouthernStar (08-25-2011)
Old 08-25-2011, 08:59 PM   #8 (permalink)
View LostSouthernStar's Photo Gallery
Yes yes, what Kevin said, please do tell!
I own a Gen 4 Camry but I never thought the Gen 6 could such great mileage due to its larger weight and size.
You made a believer out of me!
What hypermiling techniques and tips did you use??
2001 Toyota Camry 2.2L-I4, automatic transmission with 157,000 miles.
LostSouthernStar is offline   Reply With Quote
Old 10-16-2011, 12:08 AM   #9 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1215766
iTrader Score: 6 reviews
The OP sure did disappear.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 10-17-2011, 07:27 PM   #10 (permalink)
View Scott O'Kashan's Photo Gallery
Originally Posted by worthywads View Post
Good work.
If you use a tread depth gauge, you will find the center of the tire much more worn than the edges. Also, using inflation pressures that high will cause the tire to be very, very hard and not able to absorb/flex when it hits potholes etc., which can cause the tire to fail. A maximum inflation pressure of 44 psi cold is meant for high speed use to increase load carrying capacity, but it isn't the recommended air pressure.
-- B.F.Goodrich T/A Certified Tire Specialist
Scott O'Kashan is offline   Reply With Quote
Old 12-06-2011, 01:54 AM   #11 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
In other words, the tire can also wear out faster and negate any money saved on fuel.
2007 Camry 2.4L 5M
Old 12-07-2011, 05:28 AM   #12 (permalink)
Correct, as well as too high inflation pressures of 44 psi can cause the rims to dent very easily, (costly to replace), and suspension components like MacPherson struts to wear out prematurely, not to mention drivetrain components like CV joints/axle shafts, wheel bearings, tie rod ends, etc.
The correct recommended tire pressures will be listed in the owners manual or on the tire placard on the car which is a small white sticker showing the recommended tire inflation pressures. The tire placard can be usually found on the end of the drivers door where it latches to the car when you shut it, (or one of the other doors), inside the trunklid, the glove box or even on the backside of the fuel door.
I hope this has been of assistance. Take care, have a Merry Christmas and Happy New Year!
Old 12-09-2011, 09:11 AM   #13 (permalink)
Well I have been running max pressure and getting improved mpg with all my vehicles over the last 25+ years and have not seen the increased wear or uneven wear, and have never had any mechanical issues that you say will result.
Underinflated tires will wear out fast I agree, but I haven't seen it with overinflating.
Old 12-09-2011, 04:58 PM   #14 (permalink)
You've been running 44 psi air pressure in the tires and haven't noticed premature wear in the center of the tire?
Old 12-30-2011, 01:19 AM   #15 (permalink)
Diehard Rams Fan
I've not run pressure that high but I've heard the same from a lot of Prius owners that they haven't had uneven wear either.
