Online MPG Trackers - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 07-11-2009, 04:13 AM   #1 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
Lightbulb Online MPG Trackers
For ease of tracking your MPG, a few sites allow easy to use online programs to help you track your MPG.
These three sites are very useful:
For tracking:
www.gassavers.org
www.cleanmpg.com
https://www.fueleconomy.gov/mpg/MPG.do?action=garage
http://gasbuddy.com/ (not yet reviewed by me, but I've seen it around, quite similar to the epa version.)
Ecomodder.com
Offline tools:
Excel template download
Federal Numbers for input into your tracking info (setting up):
http://www.fueleconomy.gov/feg/feg2000.htm
First of all, TN has no endorsements of any of those sites listed, if you are able to give input and list a few more (with quick reviews); they will be posted also. Those listed are merely tools for the general public; TN has no other afiliation with these sites than the link.
Once you have registered, most of these sites ask for car info and federal epa mpg ratings for the initial set up. Once you are finished with that step, you can imediately begin! If you have your tank mileage and your total fuels used, you could start right away.
Quick cliffs notes on MPG:
Tank Mileage / total gallons = xx.xx MPG
Tank Mileage: Total mileage from full tank to your next fill up. MPG calculations will be more accurate if you wait until at least half of your usual tank to fill up again.
Total Gallons: Gallons of gas/petrol/diesel used to fill up the tank to full with +/- 1 or 2 clicks after auto shut off.
If you are first starting, "throw-away" your first data and recognize the second time you fill up, that tank will be more accurate as you sorta know how much you filled on the tank before and can see that you got close to the gallons filled. One can not say they have an average of xx.xx MPG until at least 3 or 4 tanks worth.
Quick reviews:
www.gassavers.org and https://www.fueleconomy.gov/mpg/MPG.do?action=garage are very simple to use. As noted before, after set up, you mostly enter the date, the mileage, and the gallons, sometimes price. There is a part to give quick comments about the current you are entering.
www.cleanmpg.com is a more comprehensive system. You will have what is already listed above and includes more data inputs such as weather, temp, and max speed.
Originally Posted by Daox View Post
Ecomodder.com also has a simpler logging feature in their garage. It has nicer graphs too IMO.
I am not too familiar with the EPA's version but as for the other two, the data you put in allows the programs to make a graph for you. The graph is a very helpful tool! If there are enough data points, you can gauge patterns, increases, and decreases at a glance. The next great feature is that they allow links which you post into your signatures here on TN using the IMG -- pic post button. Your sig will show everyone your MPG quite nicely.
Fumes
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 07-15-2009, 11:47 AM   #2 (permalink)
View Tigerotor77W's Photo Gallery
Quick question here. Given that the fuel shut-off varies so dramatically between pumps (I averaged 42 MPG on one leg of a trip and 32 MPG the second leg, for instance, even though the terrain was hillier in the first leg and the two distances were the same), without a ScanGuage, how do I know how much fuel I'm putting in when I'm doing miles/gallons used?
I can't exactly "just add" 0.5 gallon once the pump stops, so...
Tigerotor77W is offline   Reply With Quote
Old 07-15-2009, 11:57 AM   #3 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $436410
iTrader Score: 12 reviews
View bandit's Photo Gallery
Another is http://gasbuddy.com/.
Click your state and at the top, place your mouse over GAS PRICES and than go to FUEL LOGBOOK.
CarDomain
Old 07-15-2009, 12:52 PM   #4 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
Someone made a Excel Sheet to keep track of your gas mileage/usage. I modified it some and it's what I use. I'll have to upload for all to use.
deezeejoey is offline   Reply With Quote
Old 07-16-2009, 01:22 AM   #5 (permalink)
Ninja-rator
No, you don't account for the extra 0.5 by adding that much more. You just fill up to the click and stop. If you try to adjust at the pump you are corrupting the data. That's why the procedure I posted says to wait to fill at least after you've spent half your tank of gas and to then use the average of at least 3 tanks. We are trying to see how much your gas took you not trying to fit the miles into the gallons used. The + or - clicks and the average over at least 2 tanks will help to smooth out the varying dramatic shut off points between pumps. And if the variations do bother you that much, try to get gas at the same pump each time.
As for the discrepancy between the 42mpg with hilly terrain vs 32mpg flat... same distances, many variables can explain it. Could be you were coasting down the downhill while on the 32mpg flat, you just accelerate through. Should you get the same numbers 2 or so more times, we'll have to look at the variables.
Thanks dce, added.
You're right, There's formats you can download from the net, if you can find them I'll add them.
Edit: I've found and added a link from this thread: Logs, calculators and spreadsheets
Old 07-16-2009, 12:35 PM   #6 (permalink)
You make valid points, most of which I'm aware -- there's not much point to my arguing with them, as I can't duplicate that situation any time soon, so we'll see what happens the next time. Like you said, I think this is just an anomaly that will be averaged out as the size of my dataset increases.
Old 07-16-2009, 04:50 PM   #7 (permalink)
View Daox's Photo Gallery
Daox is offline   Reply With Quote
Old 07-17-2009, 01:57 AM   #8 (permalink)
Ninja-rator
Added, thanks Daox.
Old 01-06-2010, 09:51 PM   #9 (permalink)
View ToySter's Photo Gallery
Fuelly
I did not know there was a fuel section and posted in another section.
Fuelly.com.... see my sig for info... they have about every car group to compare
Fuelly
2010 Corolla S = my ride
2010 Matrix S = wifes ride
ToySter is offline   Reply With Quote
Old 01-16-2010, 02:46 AM   #10 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1215766
iTrader Score: 6 reviews
Fuelly
+1
I started using fuelly.com & it makes it fun to track your mpg & the graphs are easy to see & understand.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
