How do you tell your MPG? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 10-09-2009, 11:11 AM   #1 (permalink)
View Gamble's Photo Gallery
Are you guys just calculating it every time you fill up or does anyone make a nice display that you mount and it tells you your estitmated MPG like scan gauge. Only thing is I don't want to pay $100+ for a scan gauge.
Gamble is offline   Reply With Quote
Old 10-09-2009, 08:13 PM   #2 (permalink)
TN's Pilot in Command
Christian87N's Avatar
Gameroom cash: $111320
View Christian87N's Photo Gallery
Do what I do. Next time you fill up, clear out your trip a or b. I use a for fuel and b for oil. When you go refuel, divide the number of miles by the number of gallons, and that will be a pretty good indication of how much your making per tank. Good way to tell if your car is drinking up more fuel, or if you have low air pressure in your tires. It makes a noticeable difference.
Get on, Get in, Hold on, Shut up
-Diamond Twinstar DA42-L360
-Cessna Skyhawk 172R
-ACA Citabria Adventure
Christian87N is offline   Reply With Quote
Old 10-10-2009, 12:35 AM   #3 (permalink)
Thanks, that is what I do. I was just wondering if someone makes an electronical inexpensive gauge or something.
Old 10-10-2009, 12:47 AM   #4 (permalink)
View timefourfood's Photo Gallery
i do that with the trip A/B in the odometer and I also own a Scangauge. The Scangauge gives me instant mpg.
timefourfood is offline   Reply With Quote
Old 10-10-2009, 01:07 AM   #5 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
You have three main options.
Scangauge2 at about 250.00
KiwiMPG at about 90.00 (it's big brother is 299-features comprabale to the SG)
Ecometer by Autometer about 70 bucks.
The Kiwimpg and the ecometer are more basic and tell you mpgs. The SG2 and the KiwiMPG's big brother, the Kiwi have more functions.
Many people here on TN Own and use the SG2, I've read around the nets people seem to like the ecometer as well. I personally have a SG2.
Here is also another thread: Anyone ever tried the PLX Kiwi? Scangauge?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 10-10-2009, 05:29 PM   #6 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $2513100
This is what I do. I pull back on the vapor recovery nozzle, which allows me to fill each time to the lip of the fill spout. Not flawless, but IMO pretty damn accurate.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-11-2009, 07:19 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Is it like a diesel dispenser? It stops when the fuel touches the tube? Although with diesel you can see the fuel inside the tank and point and shoot the stuff unlike gasoline.
2007 Camry 2.4L 5M
Old 10-11-2009, 08:48 PM   #8 (permalink)
Do you feel lucky?
TrailDust's Avatar
Dunno. I've never dispensed diesel. The vapor recovery collar work on a vapor pressure basis, not fuel touching the probe. For both my Highlander and Avalon the pump shuts off early no matter how low the pump rate is set. Then, by pulling back on the collar, I'm able to get 1.3-1.4 gallons more in the tank, which is like you described where I can watch the gasoline pour down the fill spout. I hate those frickin' collars...they're so worthless....
2002 Avalon XL
Old 10-11-2009, 09:59 PM   #9 (permalink)
mikered30's Avatar
Gameroom cash: $467667
^^ Are you talking about the charcoal canister? If so it is potentially harmful to force more fuel into the tank as it can flow into the charcoal canister and is quite costly to replace.
mikered30 is offline   Reply With Quote
Old 10-12-2009, 12:01 AM   #10 (permalink)
i second that, unless you're talking about something else...
Old 10-12-2009, 03:22 AM   #11 (permalink)
Do you feel lucky?
TrailDust's Avatar
I don't think we're talking about the same thing.
2002 Avalon XL
Old 10-12-2009, 04:11 AM   #12 (permalink)
View Shane1's Photo Gallery
Where do these devices hook into, OBD?
Shane1 is offline   Reply With Quote
Old 10-12-2009, 04:15 AM   #13 (permalink)
Ninja-rator
Yes, into the OBD2 ports. Almost plug and play with minor programing.
Old 10-12-2009, 04:17 AM   #14 (permalink)
Gotcha. If you open the cap to a tank of diesel, you can see the fuel inside. This is especially easy if the fuel tank is the two steps up to the cab rather than under the vehicle with a hose.
Pull back on the trigger and fuel just sprays out like a garden hose. It does not matter if it's pointed into a tank or not - there's no vapor recovery. There's just a rubber or plastic flange, I'm guessing, to prevent fuel from splashing out. The dispenser clicks off when fuel touches the end of the nozzle.
2007 Camry 2.4L 5M
Old 10-12-2009, 04:40 AM   #15 (permalink)
I have an XCAL2 that i got to install tunes on my F150. I wonder if it can monitor MPG? Anybody in the know?
