Technical Alternator kill switch question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 03-10-2010, 08:44 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
I'm looking at my car's charging circuit diagram and it says there's 4 wires going to my alternator:
1. A big wire - must be the output
2. A white wire going back to battery through a ALT-S fuse. I guess this is for voltage sensing.
3. A red/blue wire fed by GAUGE fuse. Terminal is marked IG so it gets battery voltage when ignition is on.
4. A yellow wire. It connects to bottom leg of charge warning light and DRL module, puts out charging voltage when turning.
So if I am to install a alternator kill switch, should I tap into the white or red/blue wire?
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 03-30-2010, 12:46 PM   #2 (permalink)
View Daox's Photo Gallery
What I did on mine was start disconnecting the smaller wires one by one. You'll know when you disconnect the right one.
Daox is offline   Reply With Quote
Old 04-18-2010, 12:33 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Just to bring closure to a (not so) old, (not quite answered) question.
I did an experiment today and the answer is IG wire. Disconnect that and the alternator puts out nothing.
That's good news, because that means I don't need to build a circuit to fool it into believing the battery is fully charged.
Buy my parts
Buy my other stuff
Old 04-18-2010, 03:44 PM   #4 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Why are you doing this?
TTercel is offline   Reply With Quote
Old 04-18-2010, 05:41 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Bump an old thread? To conclude it.
Install an alternator kill switch? To effect some sort of regenerative braking and save some gas.
Buy my parts
Buy my other stuff
Old 04-25-2010, 06:40 AM   #6 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
When you say "regen Braking"... wouldn't this be a really round about way? Where are you send this energy when you're braking? Or am I looking at this wrong?
The plus side to this is that the alternator doesn't drag on the engine to charge the battery. Think reason for detaching the power steering-- less load. In this case, more for fuel economy than for power to the wheels.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 04-26-2010, 08:33 PM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Yes, roundabout as in mild to the point of undetectability. My idea is I'll let the alternator drag on the engine when I slow down. That would work better with a high output alternator = bigger drag until battery is full.
I installed this switch and a FAS switch this past weekend. I need to mosey over to cleanmpg or ecomodder for hints on using them. Next is to wire in the circuit to have alternator engage when I tap the brake.
At least my idle fuel rate is down by about 0.2L/hr with alternator disengaged.
Buy my parts
Buy my other stuff
Old 05-11-2010, 10:06 AM   #8 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
I don't think I understand quite what you're trying to do.
If you disconnect your alternator while the car is running all you're doing is taking power from the battery, there isn't any more or less drag caused by your alternator.
Stevo_Echohb05 is offline   Reply With Quote
Old 06-01-2010, 03:16 PM   #9 (permalink)
Yes, the alternator does put a load on the engine Stevo. The electricity it produces isn't free.
Old 06-04-2010, 01:03 PM   #10 (permalink)
Beware of pigs
Buurin's Avatar
Update
Brake trigger circuit wired up. Ran my battery once beyond drained and put in a Optima Yellow Top. Next is a voltmeter.
The gains, if any, is almost undetectable.
Buy my parts
Buy my other stuff
Old 06-04-2010, 03:27 PM   #11 (permalink)
Gameroom cash: $147537
^What ever saving you had is spent on new battery. But its a good experiment.
How about make a switch to work with battery voltage? Turn off alternator when battery is above a certain voltage and turn it on when battery is below a certain voltage?
Old 06-07-2010, 10:43 AM   #12 (permalink)
O.K. I agree energy isn't free, you are taking power produced by the engine to produce electricity.
I am curious though, if you took the belt off the car and spun the alternator how much torque you would need and then the the key on put a load on the battery and spun the alternator. How much more force is necessary? Enough to have an effect on fuel economy?
Also if you are running off your battery and the alt is off then you only have 12.~V in the best situations not the 14.~V that you get with the alternator running which might affect your spark
Old 06-09-2010, 12:13 PM   #13 (permalink)
A guy on ecomodder did before and after testing by removing the belt for the alternator. His testing showed a 10% increase in fuel economy without the alternator.
http://ecomodder.com/forum/showthrea...g-gain-98.html
It is quite possible that the lower voltage effects spark. I haven't seen any valid testing showing the effects though.
Old 06-09-2010, 03:08 PM   #14 (permalink)
The test he did involves removing the belt, which, depending on what else that belt drives ie; water pump, power steering pump, idler pulley, a/c. would not be putting load on the car. Also his testing method cannot be that accurate,what were the driving conditions, how far did he drive? There are so many variables to consider ie; throttle position, how fast he accelerates, wind speed, direction........ it goes on and on.
I would expect this result on any car, he didn't turn off his alternator, he removed it completely.
The easiest test
1. remove belt, spin alternator
2. turn on key, turn on all accessories, spin alternator
If it becomes harder to turn the alternator while it is charging then it confirms your theory, if it is the same then you will not see any better fuel mileage.
Old 06-10-2010, 12:22 PM   #15 (permalink)
I would agree with you and would likewise be skeptical of any testing, but I know the individual and I know how he tested.
So, I know his car doesn't have power steering or A/C. The only thing on the belt is the alternator.
He used a level strip of road 1 mile long, made multiple passes in both directions with cruise control and averaged them. He ensured there was next to no wind.
So, he pretty much did everything within his power to make it as ideal as possible. There of course still are variables, but they are minimized. He also wouldn't post info that showed that the gain was less than the inconsistency between runs.
I agree that removing the belt would show greater benefits than electrical disconnection, but I doubt its that much.
