It's not about the width, it's about the weight. A 14" tire and wheel combo will weigh less than a comparable tire and wheel in 15" size.
Getting great mileage is like speed - speed costs money, so how fast do you want to go?
Adding a less restrictive drop in air filter can help, but it'll cost an initial $30-40. Changing to synthetic engine oil can reduce friction and increase mileage while reducing engine wear, two oil changes a year (or every 12K miles) at about $75 each is a good deal versus 6 standard oil changes (every 3-4K) at $40-45/ea.
I don't think your LE has traction control, but if it does, skinny tires can play a role in how the electronic systems, right down to the ABS, perform on the road and can also affect handling.
Going to a 10-20mm narrower tread width and increasing the sidewall by 5% might help with mileage. If you don't need new tires yet, there's no point in spending the money to get them changed so you MIGHT gain 1mpg on a 30mpg highway car. It doesn't seem worth while to spend the money on it.
Just put a high flow air filter in, check your tire pressure regularly and set it toward the max (34-35psi or what ever is listed on the sidewall), take out ALL weight in the car that you don't need, such as tools, etc. As mentioned, keep speed in check, stay UNDER 70mph to get any decent mileage, especially on longer drives. EPA tests highway mileage on 2008+ vehicles at 60mph with A/C on, and before 2008 EPA tested highway mileage at 55mph with A/C off. Just to give you an idea if you want your EPA highway mileage, keep it at 60mph or lower, otherwise, don't complain.
I know it's un-American for me to say this, but too bad - loose weight, providing you're a heavier person. I lost 65lbs two years ago and noticed an increase in my mileage just from that. It was definitely worth while for not only health reasons, but for everything else as well!
'00 Durango R/T - 183,000kms (will replace with a 2.7L I4 Highlander shortly)
'99 Taurus SE sedan - 204,500kms
'06 Pontiac G6 GT - 42,000kms
