MPG after timing belt replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 05-08-2011, 05:47 PM   #1 (permalink)
A good speler
View filter's Photo Gallery
On the first tank of gas after having my timing belt replaced (by the dealer), my mileage dropped by 2.5 mpg, from the usual 20 (+-.5) mpg to 17.5 this time.
Is there anything about the timing belt replacement procedure that could go wrong that could cause this?
'02 Highlander Ltd (mine)
'09 Camry LE (wife's)
filter is offline   Reply With Quote
Old 05-09-2011, 11:20 PM   #2 (permalink)
Gameroom cash: $287485
View worthywads's Photo Gallery
Yes if put on incorrectly the timing could be off, it controls the timing.
But I wouldn't rely on just one tank.
2005 Impulse Red 4x2 Access cab 2.7L 5-speed SR5.
worthywads is offline   Reply With Quote
Old 05-23-2012, 07:59 PM   #3 (permalink)
View 1/2 ton giant's Photo Gallery
They could have effed with your timing by mistake. It is very easy to do when your not paying attention.
1/2 ton giant is offline   Reply With Quote
Old 05-23-2012, 08:59 PM   #4 (permalink)
A good speler
Yeah, I may not have worded my orginal post very well, but I was trying to ask whether the timing belt could be put back on wrongly without the tech noticing.
I posted this a while back, and the mileage (and I think the power, too) is still down from where it was pre-timing-belt-change. But since the CEL hasn't come on, I have just been living with it.
Old 05-29-2012, 12:51 AM   #5 (permalink)
View JesusJones's Photo Gallery
My gf has a 89 celica. Her dad changed the timing belt and swore up and down he put it on right. ( he works in an air hanger )
The car felt like a dog. It still drove but it didn't have that pep I remembered. Gas mileage was just a little down. Nothing was off enough to really throw any red flags in my mind.
One day with some beer on hand and time to kill. I decided to check the timing belt for myself. It WAS off by one tooth. After putting it back on properly the car was back to normal.
If it feels like it lost power and your mpg is down take it back to the dealer.
JesusJones is offline   Reply With Quote
Old 05-29-2012, 08:21 AM   #6 (permalink)
A good speler
How did you check it? I'd like to check it myself if I could.
Old 05-29-2012, 11:55 AM   #7 (permalink)
The process is different for different vehicles but it is usually along the lines of :
Removing the top timing belt cover
turning the crank pulley until the timing mark is lined up with the 0 degree mark.
then checking the camshaft pulley's mark. There is sometimes a hole or a dimple somewhere on it. If it is facing straight down turn the crank over one more time until it is lined up with 0 deg again. Then the cam pulley mark/dimple should be straight up. If it is not pointing straight up your timing is off.
Google is your friend here for finding detailed instructions
The Following User Says Thank You to JesusJones For This Useful Post:
filter (05-29-2012)
