Can I add more techron with chevron 89 octane gas - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Fuel Economy
Fuel Economy Forum for people to discuss their mileage and ways to improve it.
Old 05-24-2011, 06:59 PM   #1 (permalink)
tylerho's Avatar
View tylerho's Photo Gallery
For the past two months I have been using arco's 89 octane gas and last week i started to use chevron's 89 octane. when i was using arco the price was $4 for regular while chevron was close to $4.50. Now since gas is going down arcos price is cheaper than chevron by 5 cents. Will I be able to ad more techron when I fill up tomorrow, because o'reilly is having a BOGO sale on the techron starting tomorrow. Since I started using chevron gas again and a new wix air filter i was able to get more city mpg. please let me know. thanks
99 Camry V6 135k miles
Bridgestone Potenza re970as Pole Position
tylerho is offline   Reply With Quote
Old 05-24-2011, 08:17 PM   #2 (permalink)
Gameroom cash: $557830
View JohnGD's Photo Gallery
The O'Reilly one on sale is the concentrated.
IIRC, you can use the fuel injector cleaner almost every fillup, but the concentrated was like a few thousand miles or something like that. It has more cleaner than the FI cleaner. If you didn't already add a bottle in the tank then you can use one, even for Chervron gas.
Old 05-24-2011, 08:23 PM   #3 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
I just got 2 of them from OR, you're supposed to put it in when the tank at 1/4, right?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-24-2011, 08:36 PM   #4 (permalink)
Or as empty as possible. This allows the refueling process to "mix it up" well.
Old 05-24-2011, 09:16 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it doesn't matter much when you pour it in, I did at 1/4 tank or at almost full tank. it will mix well regardless. results were always good
use either the 20oz bottle or 2 bottles of 12oz of concentrated Chevron techron fuel system cleaner.
also the concentrated techron dose impacts the fuel trims nicely
with it in tank wife's 5s-fe trims drop down to +2 or +3% total
without it they float around +5 or +7% total.
Old 05-25-2011, 05:48 PM   #6 (permalink)
Gameroom cash: $287485
View worthywads's Photo Gallery
I don't know about the techron but the new air cleaner couldn't have improved your mpg.
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
Conclusion:
On 3 different vehicles with fuel injected engines an almost completely clogged air cleaner did not reduce mpg. But this is WAY more restricted than letting your filter go for 200,000 miles, so restricted that one vehicle damaged the intake by sucking the air filter right down the pipe!
With a clogged air filter the computer just opens the throttle plate a bit more to compensate.
2005 Impulse Red 4x2 Access cab 2.7L 5-speed SR5.
worthywads is offline   Reply With Quote
