Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Spark plug swap gone BAD - tube removal?
View Single Post
Old 07-16-2007, 08:17 AM   #10 (permalink)
CrawlingEye
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Originally Posted by Stillrunning
Smear some di-electric grease on the inside of the plug boot and you won't have to worry about trying to get some tool to remove the boot stuck to the plug.
I wish it were that easy, if you use Bosch plug wires, they seem to always get stuck with at least one of the rubber seals. Typically, I use di-electric grease around the insulator of the spark plug and inside the boot and around it.
Long story short, as far as I've had experience with:
Bosch plug wires = 2 sets that I had to pull seals out of the spark plug chamber
NGK = 1 set and no problems
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
