Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Mystery Bolt on front crossmember
View Single Post
Old 07-17-2007, 02:11 PM   #1 (permalink)
Buurin
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Here is a picture of the front suspension crossmember of my Corolla, a gen 8:
The two red circled bolts are not mentioned anywhere in the factory manual, nor are they in Haynes manual either. Right now there's a grade 8 bolt in there. The bolt circled in blue right now is a grade 11 bolt, same as the other crossmember bolts known to be torqued to 167 ft-lbs per factory manual, but it's only spec'd for 109.
But this bolt also bolts to the body, and from the look of it it won't withstand 167 ft-lbs of torque required of other crossmember to body bolts.
I just came back from the local dealer and checked out a 97 Corolla on hoist. There is a similar layout and the back bolt in the red-circled spot is indeed a grade 8. The mechanic says that bolt is torqued to about 52 ft-lbs.
Can anyone confirm? Did I unknowingly switched the two bolts?
PS. Did I pick a good spot to place a jack stand in the pic?
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
