rusty mutha
wow, glad my rolla has lived in hawaii and FL
the jack placement is fine, I have a 6 inch piece of 2x4 ripped in half and I spread the load a bit with that so my stand would be aft 3 inches from there with the wood in between the stand and boddy.
the red bolts can not be swapped, they a re short and go in direct to threads you could fuck up the blue ones if you worked at ti but again they are all slightly different lengths either markem or just pay attention to how much thread engagement you're getting when you go to put em back its really not to bad
DO use that silver antiseize (you'll be back there someday)
DO get good nutbuster juice on that cross bar nut. that is actually a long body bolt with a stud on the head for the brace
the center cross member has a sinole bolt that holds (f'in interferes) with the motor mount/cross member /frame it sux and there is no easy way to get it.
after the second time in threr I modified the ares a good bit and can now remove /replace my rear motor mount WITHOUT loosening the frame or crossmember
