Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - timing marks
Thread: timing marks
View Single Post
Old 07-28-2007, 02:39 PM   #2 (permalink)
toyomoho
View toyomoho's Photo Gallery
If a 5SFE engine, align the hole in the cam pulley up with the bump in the cam bearing cap. You should be able to see the bump through the hole. Align the crank at 0 degrees.
Install belt, release tensioner, then turn engine by hand 2-times CW and recheck the marks. If the marks are off, repeat the process.
