Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Car ran horribly now wont start
View Single Post
Old 08-07-2007, 05:06 PM   #15 (permalink)
toyomoho
View toyomoho's Photo Gallery
A bad ignition wire from the coil to the distributor cap can cause hard or no start problems.
If the car does not start again, remove the coil wire from the cap and check for spark. If spark, try a spark plug wire. If the plugs are getting spark, then the problem is elsewhere.
The link below provides access to Gen 3 service info:
http://oregonstate.edu/~tongt/camry
