Originally Posted by PiercedTiger
What do you mean by that? Top Gear could probably bring any car they wanted over here to "test".  They have a legal department and more money than any of us to get things done.
Also, up near where Artic Trucks is based you probably NEED a diesel or a helluva engine warmer to run gas. I've heard people that never shut the engine off cuz if they did it wouldn't start in the morning.
Diesel's are the ones that have a problem starting in the cold, not gasoline engines. And yes, they generally do keep diesels running in the cold. Same with hospitol ambulances that are on call in the cold weather. So they do not run into problems starting. Diesels sold in cold weather climates generally do come with block heaters, or at least as an option.
Diesels are much more thermoefficient compared to gasoline motors. Which means they lose much less energy to heat, more power from combustion is used to power the vehicle and less energy (heat) escapes.
